Fox x2 shock help
[Closed] Fox x2 shock help
[#10164020]
My x2 is making a squelching sound and after research it seems that a seal on the compression valve has given up and is allowing air to mix with oil. I will be getting it serviced on Friday but wanted to ask if riding this week will cause any more damage? The damping isn’t great but I could get by as long as it isn’t going to totally trash the internals.
Posted : 12/08/2018 9:29 am
I doubt it will damage it further. I'm so insensitive I don't tend to notice failed rebound on a succession of failed cane creeks and X2 apart from the carpark test.
However I do attribute my worst 2 crashes to failed rebound, getting pinged over the bars after jumping and 5 days in hospital, so I wouldn't use it again till it was fixed.
Posted : 12/08/2018 9:35 am
I'd ride it as it is.
Posted : 12/08/2018 9:41 am
It will not do any further damage. It's your call if the current performance level is useable.
Posted : 12/08/2018 10:00 am
The rebound damping is semi working. The compression damping not at all. It's rideable but no lockout and a bit spongey. Better than no riding though. 😉
Posted : 12/08/2018 10:35 am
