Fox transfer self /...
[Closed] Fox transfer self / mini service
[#11544410]
Is there any such thing as a mini service for a fox transfer seatpost - clean and relube type thing. Or is it a full strip down involving lots of bits pinging around the garage?
Posted : 15/12/2020 5:06 pm
Afaik a service requires tools that Fox will not sell to the public, could be wrong tho but I don't know anyone who has tried it themselves
Posted : 15/12/2020 6:02 pm
 RicB
I’ve just done my Race Face Turbine R, which is the same post with a different seat clamp
Instructions
I got as far as step 9 but didn’t have the threaded rod so couldn’t get the wiper seal and bushing out
But I did clean a load of crud out and put a few ml of oil in that bottom part, which lubricates the grooves the keys slide along
It’s much better now, whereas before it was reluctant to return
Posted : 15/12/2020 9:14 pm
You can do the 'mini' service yourself without special tools but you will need a whole new seal kit as you have to replace the wiper and upper IGUS bush. At Step 8 where you remove the retainer lug from shaft-
-clamp the post in a vice
-you need a plastic tube which fits over threaded section of the shaft-end but contacts the flat end
-keep on tapping gently against the tube/shaft and gradually the you will see the wiper seal start to unseat and then become free followed by the upper IGUS bush (which will break up in the process)
- at this point sliding shaft is free to remove and you can then skip the steps until it comes to step at which the sliding shaft is re-inserted - you can push the wiper seal back in by hand
Posted : 16/12/2020 11:30 am
