Fox rp23 rubber rin...
[Closed] Fox rp23 rubber ring?
[#1908635]
The rubber ring that shows how much travel you are using has snapped. Had a quick look online and it seems you have to buy the whole seal kit just to get the one ring I need. Will probably service it myself anyway but would be good to get just the ring I need for now. Any aftermarket or diy fixes?
Dan
Posted : 18/08/2010 7:53 pm
It does sod all really, so you could just ignore it. If you must have one, then try your local car spares shop, they'll have a selection for pennies.
Posted : 18/08/2010 8:02 pm
Thanks coatesy. I know it does sod all but nice to keep and eye on what's happening with the travel and sag really. Good call on the car spares , will give it a go.
cheers
Posted : 18/08/2010 8:23 pm
Or Plumbing supplier...
Posted : 18/08/2010 8:24 pm
Eh?
Put an elastic band round it you plonker!
Posted : 18/08/2010 8:32 pm
I thought this was what dirt was for, to leave a clean/grime tide mark on my forks so I can see where my travel is at.
But then really, if I'm not shaking my teeth out then I figure the forks are working and all is good.
Sag, well, that's measured in inches of gut over my belt.
Posted : 19/08/2010 2:36 am
zip tie
Posted : 19/08/2010 2:56 am
just use a small zip tie loosely secured, a slip fit tightness; I use zip ties on front forks and my RP3 raer for this purpose
Posted : 19/08/2010 7:54 am
Cut a thin section of old inner tube, slice it to turn it from a loop into a string, tie round shock in an attractive double overhand gusset hitch.
Posted : 19/08/2010 8:02 am
B&Q, pack of assorted O-rings for 50p. Unbolt shock rear, slip on and re-bolt.
Posted : 19/08/2010 9:16 am
Nice one guys cheers for the info.
Posted : 19/08/2010 3:06 pm
clean each end and superglue it back together? Works on old music cassette drivebelts.
Posted : 19/08/2010 3:12 pm
