Fox RP23 oil change...
[Closed] Fox RP23 oil change.Possible?
[#1654650]
Anyone know if its possible to change the oil yourself while you're doing an air can service on a RP23.
Posted : 29/05/2010 2:16 pm
i want to learn to open mine up so i know how to service it my self lol
Posted : 29/05/2010 2:24 pm
MBUK,isn't that a kiddies mag?
Posted : 29/05/2010 2:46 pm
Don't think you can do either yourself, kiddies!
Posted : 29/05/2010 2:50 pm
Think you can only service the air spring. The damper is nitrogen charged and dangerous to tamper with.
Posted : 29/05/2010 2:52 pm
A simple yes or no would do!
no
Posted : 29/05/2010 2:54 pm
Thanks mudmonster.Can't find any info on internet about oil change so maybe its not possible.
Posted : 29/05/2010 2:55 pm
possible, but requires lots of expensive kit so unless you plan on doing 100's of shocks, MOJO/TFT will be cheaper.
Posted : 29/05/2010 3:03 pm
I remember seeing a link on here to a Russian site where someone had managed it. Was just a matter of pressurising and replacing the seal on the floating piston correctly. Don't have a link though.
They did just charge it with air and not nitrogen but I get a feeling that that isn't as important as it's made out to be. After all, the RS Monarch shocks are only air charged.
Posted : 29/05/2010 3:05 pm
I know how to do it, but havnt done it as yet. Changed oil on dhx's and the basic principle isnt any difference. Big difference is that dhx's have a schrader valve to pump air into, fox air shocks dont. They use a rubber pellet compressed with a grub screw..the russian guy managed to make some needle device fitted to a shock pump to mimic the fox nitro charging tool.
Air would be fine instead of nitro...the water content in air is the reason they use nitro, so a nice dry day and you'll be fine. Pressue wise fox upped the pressure from 300psi to 400-500psi a few years ago as they had problems with larger riders bottoming too easily...300psi (normal shock pump pressue) wouldnt be a problem unless you're heavier than ~14st and ride hard.
Only reason i havnt tried it yet is my shock isnt in need of a service...if it was i would have a bash and if it failed/poor performance then i would send it off...would be no more expensive for the service.
Posted : 02/06/2010 10:42 pm
