Fox qr 15mm air pre...
[Closed] Fox qr 15mm air preload queries?
[#785651]
I'm hoping someone can assist with the f-series qr 15mm forks soonish as I'm preparing for a ride right now.
My cd-rom manual won't work on my dated dell and I need to know what air pressure to put in the fork for a big chappy rider weight.
Can anyone check with the cd-rom manual the correct air pressure for a 16st 11lbs rider please.
(you can use any 300psi shock pump can't you, i.e. rockshox fork pump?)
Also the qr15mm bolt thru axle/lever assmebly aren't pointing towards the back of the bike when fitted and tight, they seem to point forward and upwards. HOW do you change this as I see a allen key adjustment on the other end of the fork legs with numbers printed on them.
I've literally just got the forks so need some friendly pointers, thanks,
whyter.
Posted : 15/08/2009 10:26 am
upwards and forword is how fox set them so thats ok, air pressure guide is pretty out so best to set 20-30% sag with ziptie on stantion an any normal pump will work fine,
Posted : 15/08/2009 10:47 am
there's an air pressure table and qr15 instructions in the owners manual [url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/09/Eng/2009_OM_eng.htm ]here. [/url] As khani says, the qr lever should be pointing up and forward.
Posted : 15/08/2009 10:58 am
