FOX High Volume RP2...
[Closed] FOX High Volume RP23 Air Sleeve
[#977482]
Best source?
Quick Google gives nout...?
Posted : 22/10/2009 10:15 pm
Mojo?
Posted : 23/10/2009 6:02 am
why do you want one? Have you damaged yours?
Posted : 23/10/2009 8:11 am
Just want to try a HV can.
Had one on a multi-link FS a while ago and it improved the stroke feel, and amount of travel.
This bike is a single pivot so not so sure it will work as well...?
Posted : 23/10/2009 11:15 am
I think I've got an almost new one (5 rides?) that came off the RP2 I put on my Prophet (if you're thinking of putting it on a Prophet, don't!).
I'd have to check, but you can have it for £15 if you want/I still have it.
Failing that, I got my low volume one from mojo. It was about £30/35 plus postage, I think.
EDIT - just read the single pivot bit. On my prophet, the larger volume meant I raced through the travel really fast. Much improved by putting the standard sleeve on.
Posted : 23/10/2009 11:26 am
Thanks for the offer Brown. I'll give it a go. PM you in a bit
Posted : 23/10/2009 11:46 am
Sorry mate, scratch that. I can't find it anywhere.
Mojo's the place to go though. I rang them before buying mine and they were pretty helpful about which cans would work and suggestions as to how I could bodge the HV can to work like the standard one. I'd give them a bell.
Posted : 23/10/2009 11:54 am
what tune is your RP23? I mean compression/rebound tune? What bike is it?
Posted : 23/10/2009 12:01 pm
It's a [url= http://www.bikemag.com/gear/bikes/lenz-behemoth/ ]Lenz Behemoth[/url]
Sorry, not too sure what you mean tune. Do you mean what I've set it to?
Posted : 23/10/2009 12:08 pm
if you look on the air can it will say by means of some graphic symbols, there are 3 symbols
if one symbol is high lighted then it is a low tune, if 3 are highlighted then its heavy?
Posted : 23/10/2009 12:11 pm
Thanks for that. I'll look when I get home at luchtime and post it back up
Which tune would are we hoping for?
Posted : 23/10/2009 12:15 pm
well my HV sleeve on my RP23 is low compression/rebound and the shock is crap!!! Not very supple and blows through the travel very easily - so you have to run less sag to stop it bottoming but small bump compliance is shite! Santa Cruz spec these shocks but are useless on single pivots.
What I have done is put a shim in to reduce the volume of air - totally better shock now (i run more sag, its very supple and fails to blow through the travel) - however im gonna get a coil as a Heckler performs better with one!
Posted : 23/10/2009 12:20 pm
There are 3 sticks and an arrow pointing to the longest
Posted : 23/10/2009 1:01 pm
ok high tune then!
are you happy with the shock ATM?
Posted : 23/10/2009 1:57 pm
Fairly, yes. I suppose I would like a little more efficiency on pedaling, a little more travel, oh and less packing up under braking, with a sweeter feeling trail action!
Seriously, as you seem better versed in suspension than me, what characteristics are likely to change with a HV can?
Like I said, changing to one on a multi-link FS gave more travel, and a more linear action - no ramping up
I have a feeling on a single pivot it may not work quite as well...
Posted : 23/10/2009 3:01 pm
I wouldn't recommend it on a single pivot but your probably best speaking to tim at tftuned-they are experts!
Posted : 23/10/2009 4:01 pm
Gotcha. Cheers for that, I'll give them a call
Posted : 23/10/2009 6:05 pm
I've got an 07 Heckler with a large volume can on the RP23. The large volume can is a sleeve over a standard can connected with a hole in the standard can.
I agree with above, blows through its tavel too easily so I have the outer can full of grease to reduce the volume.
(14st - Large Frame)
Posted : 25/10/2009 9:25 am
I've not seen the large can fitted over the standard one.
When I tried a HV on a previous bike it came as separate can you fitted by itself
I think I'll give one a whirl, as I posted a question on a [url= http://forums.mtbr.com/showthread.php?p=6241817#post6241817 ]MTBR thread[/url] which returned ambivalent feedback
Posted : 25/10/2009 9:50 am
The large can is a seperate item, but when it comes you will see it is effectively a sleeve over a standard size sleeve, joined with a hole.
Posted : 26/10/2009 1:50 pm
