fox forks pressures
[Closed] fox forks pressures
[#857078]
just an observation but i would appear to be running both my forks well below fox pressure recommendations. At around 185lbs rider weight fox recommend approx 90psi, i run mine at 70psi and still dont get full travel. Am I just light on my forks or is this the same for other people?
Posted : 10/09/2009 4:07 pm
Me too. I set mine on desired sag and monitor travel with zip tie. Optimum pressure is much lower than Fox tables recommend - I've found tables only good as a starting point.
Posted : 10/09/2009 5:06 pm
me - 175lbs, so 185 on the bike. Float 32RLC's - 65 -70 psi
Posted : 10/09/2009 5:10 pm
I use 100 psi and get full travel, me = 200 lbs
Oil level chaps??
Posted : 10/09/2009 5:37 pm
me 225 lbs ( 😯 ) - IIRC fox recomendation was about 110 psi (32RL) but i'm currently running 80-85 PSI.
Also using the zip tie measuring method....
Posted : 10/09/2009 6:01 pm
Same same......185lbs, should be 90psi but just realised I was pinging off rocks 'cause they were too hard. Ignore the manual, trial and error, use the zip-tie. I run mine at 70 now.
Great when you get them right.
Posted : 10/09/2009 6:54 pm
careful with the zip tie at full compression ending up embedded in the seal !
Posted : 10/09/2009 7:40 pm
I dont use the weight chart. I do it by rubber O ring on fork and
like it at 35 mm sag on a 160 Talas, easy to keep your eye on.
Put a rubber O ring on your fork when servicing your Forks
it wont scratch your stanchions
Posted : 10/09/2009 10:33 pm
