Hi, can anyone tell me the grading/level of Fox forks from low entry to top of the range, there is various of Fox forks like F-series, Talas, etc...
No wise cracks please, just sensible replies if any please.
Thanks
All pretty top of the range just ones with less adjustments are deemed worse
F-series don't have the honeycomb structure inside the brace. Guess there are other weight saving features too. Think the damping will be just as good throughout the range, but a few less adjustments. I heard that with f-series the travel can't be changed with internal spacers like with float. Not sure if it's true or not. Anyway I'm drunk and probably waffling crap.
I disagree. Cheaper yes. But worse? Sometimes less is more. As with some Talas RLC's. Some reliability issues occurred in the past with all that going on. The Talas R's may have been more reliable.
Ok I worded that wrong. Depends on if you like fiddling alot, just having the rebound adjustment is fine
