fox fork help !!!!
[Closed] fox fork help !!!!
[#1562570]
Thought I would service my fox 32 vanillia with new wipers etc but I was unable to remove the lower legs . The right side 10mm threaded stud at the bottom of the fork was stuck to the lowers for some reason , i have removed the crush washers and nuts and used a soft headed hammer . Also on the left stantion there is quite alot of wear , i;m quite sure this is a bad sign , your help would be great, bought these second hand so dont know if they have ever been serviced ????
Richie
Posted : 30/04/2010 7:47 pm
the service instructions on both the Fox and Enduro fork seals web sites recommend that you slacken off the foot nuts a couple of turns max then give them a sharp tap with a soft faced mallet to project the faces
I'd recomend looking through there guides once before attempting anything...
stanction wears not a good sign, but doesn't mean the end of the useful life of the fork, it's probably a waste to fit new seals if the stanctions are badely worn, but you can certainly squeeze some useful life out of even badly worn ones through doing a top and bottom lubrication service on them until you make up your mind if you want to invest in new stanction's and bushes
Posted : 30/04/2010 8:00 pm
