Fox Fork Advice
[Closed] Fox Fork Advice
[#4966561]
The lockout and compression adjuster on my rp24 fotks has packed in. Forks still travel the full distance and feel smooth. Any ideas on a fix. I stripped everything down last weekend to do a seal change so happy taking them to bit( it had stopped working before this)
I have searched for a replacement inners but cant seem to find any. Any tips or hint?
Posted : 16/03/2013 10:43 am
Sounds like a problem with propedal and lock out.
Or have you backed the lockout/propedal force knob off counterclockwise?
Posted : 16/03/2013 11:06 am
No the lock off turns freely with no effect. The propedal doesnt move at all.
Posted : 16/03/2013 11:16 am
You probably have the lever in the wrong place on the rotation. Take the lever off and wind the adjuster clockwise until it stops. Then put your lever back on. Had this on a pair of a mates. He bought them cheap because they were advertised as the lockout not working. They work perfect after this.
Andy
Posted : 16/03/2013 1:33 pm
