fox float forks
[Closed] fox float forks
[#7529206]
I have got 2014 fox float forks in 150mm at the minute. I have just got a different frame that requires 160mm forks. so I rang mojo and they said I just need a different shuttle bumper and no other parts to convert. that should be here for Tuesday to get it fitted.
ive looked t videos on mojo but its confusing as its from 2013 and shows instructions for 3 different air springs at once.
has anyone done this conversion or dropped the air spring out? is it as simple as the usual lower leg service procedure and removing the small retaining clip then neg plate then lower the air spring out the bottom?
thanks
Posted : 20/12/2015 8:28 pm
