Fox 36 Van RC2 Serv...
[Closed] Fox 36 Van RC2 Servicing
[#4842312]
Hey folks,
Some background - I have serviced various forks and shocks before but never this particular pair.
Really I just want to replace the dust wiper seals and leave the dampening cartridge alone (unless this is a bad idea?!). I've got the new seals, crush washers and 10WT oil here from Mojo. Can I just remove the RC2 cartridge and then replace without cycling any of the oil out or will it cock up the levels?
Alternatively does anyone know if / where Mojo list all of the consumables needed to re-build the cartridge? That may be an easier option.....
Paying Mojo to do this is out of the question (especially now I have most of the parts bought!). So please no "you should just send it away comments" - I like to do the work myself and it's not back fired yet.
Thanks,
Oli.
Posted : 06/02/2013 2:13 pm
Also anyone know what the difference between the RED and GREEN oils is? Appear to be the same weight (10 WT). Any reason I couldn't just use green for everything?
Posted : 06/02/2013 2:17 pm
YES its very easy!
Posted : 06/02/2013 2:24 pm
Cool....Thanks tmb467 I had that screen open on another tab but freaked out a bit when I saw lots of mention of draining oil from the cartirdge. Have now read it all the way through and realise that as long as I leave the cartridge closed I don't have to worry about the red oil etc. Will check for play (air) in it before replacing though.
Thanks folks....
Posted : 06/02/2013 2:29 pm
