formula megas or de...
[Closed] formula megas or deores?
[#6363043]
looking for a cheap set of brakes, which are more reliable? Have modulation? reliable?
Either of the above?
Posted : 24/07/2014 9:24 pm
 rj
Buy the Deores and I'll swap you for my Megas. They're great when they work, but mine have intermittently sticky pistons, rub more than half the time and the one time I tried to bleed them had me seriously considering suicide.
And it's 25 quid for the wee screw that holds the pads in.
Posted : 24/07/2014 9:34 pm
Shimano, I had the nightmare of living with formula the one brakeset for a couple of months. As above but also they'd make different noises on each ride. If it was wet I'd be afraid to use them
Posted : 24/07/2014 9:43 pm
Swapped from megas to deores for much the same reason as rj
Posted : 24/07/2014 9:59 pm
Swapped from Avid's to Deores. Will never look back. So easy to set up, so much power.
The girlfriend has low-rent Shimano disc brakes on her hardtail (think they are Alivio or Acera) and even those are pretty awesome.
Posted : 24/07/2014 10:05 pm
on my scott aspect ( 2008) brakes were no name shimano hydraulics, still works well ( loose levers....) after almost 5 years of use, only change for shimano "shiny" XTs 🙂
Posted : 24/07/2014 10:08 pm
Cheers so shimano it is
Posted : 24/07/2014 10:25 pm
Had Formula OROs, they were awesome when they worked (like, stop a freight train awesome) however they rubbed constantly, and suffered from sticky pistons etc.
Swapped them for new Deores a few months back, performance is just as good, and they don't rub.
Buy the Deores.
Posted : 24/07/2014 10:42 pm
M615s on sale at planet x at the moment or crc. Damn good brakes. Theres a crc code for 12 off 60 on here somewhere.
Posted : 24/07/2014 11:25 pm
Bog standard Shimano brakes on all my MTBs.
They're good, and very cheap.
Posted : 24/07/2014 11:28 pm
