Formula K24 pads?
[Closed] Formula K24 pads?
 gamo
[#474232]
What do people recommend?pads that came with them(not sure which)haven't
lasted very well so any info appreciated!
Posted : 15/04/2009 3:36 pm
Superstar sintered seem to be lasting quite well. Certainly better than Formula's own sintered offering.
Posted : 15/04/2009 3:41 pm
Ditto with Bimbler.
Used no other brand since, great product.
Posted : 15/04/2009 4:11 pm
Wouldn't go near SSC with a shitty stick myself.
Fibrax semi metallics. Last very well, awesome modulation. Also using their sintered on the back, good pads, excellent life, not quite as much bite.
Posted : 15/04/2009 4:13 pm
 gamo
have read that you need to file the fibrax and some others to fit! is this right?
Posted : 15/04/2009 4:20 pm
Mine dropped straight in. Just make sure you push the pistons back fully, then get a bit of heat into them.
Posted : 15/04/2009 4:22 pm
Used Official sintered and organic pads and so far have been really good. Tried SSC normal pads - rubbish, lasted one ride a pair. Replaced FOC with sintered so about to give them a go.
Posted : 15/04/2009 4:36 pm
I think I have EBC on the front and have had no problems; Formula on the rear if only because the original pads lasted so well.
Goodridge have reasonable reviews but apparently don't come with the inter-pad spring; I couldn't find Koolstop ones anywhere in stock.
Posted : 15/04/2009 4:44 pm
I used the OME pads & they were poor didn't last long plus they cost £15 a set.
Changed to Superstar and I've used both organic & sintered pads with no probs. Both great value for money and better,IMHO, than the OME ones.
Posted : 15/04/2009 5:35 pm
