forks help please
[Closed] forks help please
[#8268349]
hi guys I have a set of 150-135-120 adjustable RS U Turn single air forks but while riding yesterday I noticed that I only had 120 travel even when the turn key at the top of the leg was turned to max .
this evening I have tried to set the air pressure in the forks but nothing changed, I have had to inflate to 250psi to get them to move to 135mm of travel but cant achieve the full 150mm travel .
forks moving up and down as normal just no travel adjustment any ideas ?
Posted : 03/01/2017 8:38 pm
Possibly bad news I'm afraid (if it's the same problem I had).
I had some Revelation Team U-Turn 150-120mm forks about 3 to 4 years ago and on their 2nd ride from new, they got stuck down in their travel after I hit a large hole at speed. The cause was a faulty batch of U-Turn cartridges, and mine were fixed under SRAM's warranty within a week (replacement cartridge). There was a loud 'clack' noise when mine went, sort of like a cir-clip snapping out of place.
At the time, I was able to find a few other people with the same fault, but now I can only find one reference to this online:
http://www.rotorburn.com/forums/showthread.php?200269-Problem-with-2010-Revelation-U-turns
It's possible your issue is something else though, especially if you didn't hear any noise when it went.
Good luck.
Posted : 03/01/2017 10:46 pm
Revelations? No help on the issue but if it's the spring side gone kaput there's a decent selection of cheap spares on the Planet X site, quick glance and they have revelation air assemblies and sector coil assemblies instock for under £20.
Posted : 03/01/2017 11:07 pm
Thanks guys I have a feeling its going to be more expensive to repair than to replace with a second hand set . might go solid front end for now as was thinking of moving up to 650b anyway .
Posted : 04/01/2017 8:38 pm
New bike time?
Posted : 05/01/2017 2:00 pm
