Fork/frame spacer t...
[Closed] Fork/frame spacer to prevent damage?
[#9385134]
Flying with the bike for the first time next week. Whats good to use to stop the forks and frame getting bent in transit?
Posted : 16/06/2017 10:59 am
Copper/aluminium tube cut to the right lengths between the dropouts
Posted : 16/06/2017 11:05 am
Evoc bag or similar.
Posted : 16/06/2017 11:13 am
The Evoc bags look good but bit pricey as im not gong to be flying that often, ive got a cheap crc one which im planning on padding out a bit. Ill see if i can find some metal tube then!
Posted : 16/06/2017 11:21 am
I used a length of studding with 4 nuts to hold the dropouts in the right alignment
Posted : 16/06/2017 11:23 am
 nerd
Old hubs.
Posted : 16/06/2017 11:48 am
Saw [url= http://www.hargrovescycles.co.uk/catalogsearch/result/?cat=0&q=bopworx ]these things[/url] from Bopworks a while ago, haven't tried them though.
Posted : 16/06/2017 12:28 pm
New forks and frames come with spacers for the same reason so maybe ask your LBS if they have any in the bin you can have?
Posted : 16/06/2017 1:04 pm
Length of PVC pipe, cut to size, secure with axles.
Posted : 16/06/2017 1:29 pm
Was just about to suggest the same thing! 🙂
Posted : 16/06/2017 2:22 pm
Have you got any old hubs lying around?
Posted : 16/06/2017 4:35 pm
No old hubs unfortunately, tried lbs but they only had fork spacers for qr forks, suggested cutting down some thick cardboard tube. Ive found some chipboard with a hole cut through a i can use on the back though.
Posted : 16/06/2017 5:00 pm
