Flat/Wide bar recom...
[Closed] Flat/Wide bar recommendations.
[#7096927]
I need some wide flat bars for my new bike.
any recommendations please!!
cheers
Steve
Posted : 29/05/2015 9:29 am
budget?
how wide is 'wide'?
sweep?
pootling round some field edges, or hucking off cliffs?
i like my Ritchey trail 2X, they were £25, 740mm, 9degree sweep, and 285grams.
9 degrees is about the limit before it gets a bit 'niche'. 740mm isn't *that* wide, but it's where my wrists are happy, 285g is a bit on the skinny side for an Aluminium bar, so they've gone on my hardtail, not my #Enduro_Gnarpoon.
Posted : 29/05/2015 9:44 am
Wider than 750mm (this is what my risers were? do you go same width in flats??)
Going on my only mtb which is used for everything.
I dont want to much sweep as that shortens the cockpit length.
Posted : 29/05/2015 9:48 am
Kingdom ti
Posted : 29/05/2015 9:51 am
Wow they look lovely !!
Shame they arent a bit wider !!
Posted : 29/05/2015 9:53 am
££ SS Helium carbon
££££ Syntace Vector carbon
see also Kinesis Strut (but they have too little backsweep for me)
Posted : 29/05/2015 9:55 am
I've some On one el-guapo's (800mm), nukeproof warhead 760mm and on-one knuckleball (777mm). All cheap-ish and good. Although the knuckleball is a riser, and they only do the 777mm version in hard, which is brutally stiff, probably fine with suspension but a killer on my Fatty!
Does anyone know of any wide but swept back bars? Like a 780mm version of On one's OG bars?
Posted : 29/05/2015 10:04 am
If you can find them still these are a very comfortable, wide, flat bar:
http://www.bikeradar.com/gear/category/components/handlebars/handlebars-mountain/product/review-sunline-v-one-os-flat-bar-10-39731/
I run them on two bikes but when I was after a third I went with one of these:
http://www.on-one.co.uk/i/q/HBTIEGAF/el-guapo-ancho-flat-handlebars
Cheaper, marginally heavier but very similar in feel. Cheap too so if you didn't like them its nothing really lost!
Posted : 29/05/2015 10:18 am
Thomson Carbon.
Yum
Posted : 29/05/2015 10:27 am
sunnline 762 - cheapy cheapy
Posted : 29/05/2015 10:31 am
 nuke
Depends if you mean flat or flatish...ive 2 flatish bars, both 12mm rise, sat on my table here: Thomson carbon Trail 750mm wide & 210g or SS Flatland 780mm & 330g...Thomson is lovely but the Flatland looks good also and has a nice finish plus, with Mondays money off code, cost me just over £26 and arrived very quickly with sweets 🙂
Posted : 29/05/2015 10:40 am
On-One el-guapo flats! They were selling them for a tenner. Amazing bar for the money!
Posted : 29/05/2015 10:46 am
I thought you hadn't ridden it yet?
Posted : 29/05/2015 6:19 pm
I've got some Syntace 800mm alloy bars, but swapped back to Kingdom Ti, plenty wide enough
Posted : 29/05/2015 6:44 pm
I haven't ridden it yet but the bars that came with it are 700mm wide.
I haven't used anything that narrow since 1998.
Posted : 29/05/2015 6:46 pm
fair enough, I'll give you that one 😉
still worth a quick spin to check if you really want flats though
Posted : 29/05/2015 6:58 pm
As most people have said the front of the 29er is already high. I think a set of risers will make it to high to be honest.
Posted : 29/05/2015 7:06 pm
Kingdom Ti, cut down to 700mm wide on both of my race bikes. Very comfy and I have absolute trust in them.
Posted : 29/05/2015 7:19 pm
RSP Ego DH? Haven't used one but good weight and sensible looking angles, great price.
Posted : 29/05/2015 7:36 pm
Burgtec RWR bars. Not the cheapest but look lovely and feel great at getting weight over front end (oh........and British too!).
Posted : 30/05/2015 8:42 am
YGM Renton, might have just the ticket for you.
Posted : 30/05/2015 9:02 am
