fitting wire bead t...
[Closed] fitting wire bead tyres
[#9546149]
Looking for a maxxis shorty 2.5 width but the only ones around are near enough full price so Im tempted by a 2.4 wire bead which is a lot cheaper.
Are they a pain in the arse to fit/take off (DT SWISS E1900 wheels)?
And do they set up tubeless ok?
James
Posted : 12/09/2017 7:45 pm
Makes little difference. That's not to say it'll be easy just that you can't say if it'll be easier or harder based on that alone
Posted : 12/09/2017 7:48 pm
Wire bead tyres are often made with inferior rubber so won't be nearly as grippy as top end folders . Odds are they will be harder to inflate tubeless than folding versions of the same tyre .
Posted : 12/09/2017 7:54 pm
I have a Shorty and HR 2 wired DH on a set of E1700s, Super Tacky and 60a (I think), respectively. Tubeless, of course.
Posted : 12/09/2017 8:10 pm
cheers gaidong, any issues fitting/setting up tubeless compared to the folding bead single ply versions?
Posted : 12/09/2017 8:25 pm
Exactly the same, some might be a pain, others less so. Definitely trickier than a proper tubeless tyre though.
Posted : 12/09/2017 8:44 pm
No problem inflating due to the stiff carcass, but sealing is another matter...
Posted : 15/09/2017 8:43 pm
