Fit a cog expander ...
[Closed] Fit a cog expander thingy to Sram rival 22
[#6872084]
Pretty much as the title says, i've got a cyclocross bike with sram rival 22 throughout. The easy gear is just too hard for the peaks and mud, 36t inner chainring isn't small enough, but wonder if I could fit a cog expander to the back?? not sure if it would fit, what size I could go to and is there anything else id have to do. Cheers!
Posted : 18/02/2015 6:42 pm
What's the ratios on the current cassette?
You'd need to calculate mech length needed etc.
Try harder?
Posted : 18/02/2015 6:45 pm
Im trying my hardest, trouble is I just can't turn the pedals without wheel spinning on a lot of the steep/muddy climbs. hate having to get off and walk when I know I can clear the same sections on my mtb. Ratio of cassette I think (not got it here to look at) is 11-32.
Posted : 18/02/2015 7:24 pm
Shoulder it and run? It's a cross bike afterall!
Posted : 18/02/2015 7:48 pm
Shoulder it and run, I've never heard of that brand of expander cog before, where can I buy them??
Posted : 18/02/2015 10:11 pm
I've had the same problem. Found a PG1170 11-36 Cassette and have just fitted it. Seems to be fine as a replacement, no need to fiddle with B screws or indexing.
I don't have any experience of cog expanders, but the rear mech looks like it could handle a 40 tooth cog without the top jockey wheel touching the cassette.
Posted : 18/02/2015 11:15 pm
Cheers for a helpful reply, its only when you actually use the bike up step muddy climbs do you realise the limitations. I can see why many people have a mtg chainset on instead to gain easier gearing. I'll look out for the 36t cassette, that combined with a 34t chainring could be my answer!
Posted : 19/02/2015 6:26 pm
I've had a look at the PG1170 11-36 Cassette, and on the website it states that its only compatible with the Force CX1 Medium Cage Rear Derailleur featuring X-HORIZON. Also they are pretty pricey and my cassette isn't worn at all yet (only had it a month or so) so whilst that could be an answer, I'm still interested if anyone has put an expander cog thingy onto a normal rival 22 cassette. Anyone?? 😯
Posted : 20/02/2015 10:30 am
Can you replace the 32t cog with a 36t cog from a cheap cassette?
Posted : 20/02/2015 12:31 pm
That's what I was getting at, 11-36 cassette and long cage mech (MTB). Don't know which are compatible, but the expander are to add extra teeth to MTB cassettes, so doubt you'd need it/get it set up.
Posted : 20/02/2015 5:02 pm
I've got the Sram Rival version of the Pickenflick, so the medium cage Rival mech works with the 11-36 cassette. The cassette came from the German Bike Components site and was about £66 including postage.
Posted : 20/02/2015 8:04 pm
