Finish line XC or D...
[Closed] Finish line XC or Dry lube
[#1685058]
I just got a packet from wiggle and i had ordered the finish line XC lubricant as that is what i tend to use all year round. They sent out the Dry stuff. I don't really want the hassle of changing it so I wondered what people on here thought. Is the dry stuff better/worse or should i have them both and use them at different times?
Posted : 08/06/2010 3:42 pm
If the Finish line dry lube, is the red cap one, then yes I like it a lot, I prefer it too most of all the others I have used particularly the Muc-off dry lube I bought recently, which I dont like one bit.
Posted : 08/06/2010 3:45 pm
I prefer the dry one - cleaner but need to apply it more often.
Posted : 08/06/2010 3:46 pm
In wet conditions, I use the wet stuff, but when it's dry & dusty I use the dry.
I think you should re-apply the dry stuff if you are out all day.
So, you might as well keep hold of the dry stuff - you might have a week to use it at some point this summer! 😉
I find the dry stuff is really good if the weather is dry.... needs to go on a clean chain though, else it doesn't seem to stick.
XC seems to stay on through any weather... though will eventually wash off in torrential down pour.... dust and crap seems to stick to it though so chain needs a good clean between lubes/rides.
Posted : 08/06/2010 3:47 pm
dont really use finish line stuff, but i have had wiggle send out the wrong stuff a few times recently.
Posted : 08/06/2010 3:50 pm
Dry lube is far better than the XC, that just turns to sludge on your transmission!
Posted : 08/06/2010 3:52 pm
