Fight with a minion
[Closed] Fight with a minion
[#8038271]
Hello all
Got a new set of hope hoops yesterday (oh yeah) and the rear wheel went together fine with a maxxis ardent on it, came to do the front and put a minion dhf on I've never had to fight so hard in 15 years to get a tyre on but now the tyre is on its gone deformed and has a wobble in it. I've ramped the pressure up to 70psi to see if it would get rid of it but no joy. I wonder if it will come out over time? Anyone have any ideas or suggestions?
Cheers dave
Posted : 06/09/2016 9:50 am
Is it wobbling cos the carcass/tread is crooked, or because it's not seated properly?
Posted : 06/09/2016 9:53 am
It looks seated ok.
Posted : 06/09/2016 10:19 am
Check the stitching line that is visible ~3mm beyond the rim, sounds like the bead is not sitting right on part of the tyre.
Deflate, squeeze affected part of tyre a random number of times, re-inflate and check stitching again.
Posted : 06/09/2016 10:20 am
I'll check the stitching tonight, cheers.
Is it possible to damage the wall of the tyre while installing it?
Posted : 06/09/2016 10:27 am
[quote=allmtndave ]I'll check the stitching tonight, cheers.
yep, I put a buckle in one somehow. Failed spectacularly later on!
Might have been a manufacturing fault I guess but it looked okay before I inflated it.
Posted : 06/09/2016 10:31 am
I inflate the tyre to 70psi so the inner tube pushes the tyre into the rim to seat it better.
Posted : 06/09/2016 10:45 am
Spray or wipe the bead with a little soapy water first and it will slip on and seat much easier.
Posted : 06/09/2016 11:37 am
Aren't the hope hoops tubeless rims?
Using tubes can quite often turn the whole thing into a farce.
Posted : 06/09/2016 11:41 am
Posted : 06/09/2016 11:59 am
Dammit too slow ^^^
Posted : 06/09/2016 12:56 pm
Might be Maxxis thing- I've buckled a Minion and an almost new HR2 recently
Posted : 06/09/2016 2:14 pm
I went off Maxxis tyres after having two Ignitors LUST tyres warp when set up on UST rims. There was an awful wobble in them that I just couldn't get rid of, they were sitting perfectly on the rim too. Shame as I loved the grip from the tyre, but the wobble was horrible.
Posted : 06/09/2016 2:20 pm
Let the air out and man handled the tyre into place as it wasn't sat quite right. Now its the same all round but there is still a wobble, not as bad as before though.
Posted : 06/09/2016 9:05 pm
