Engineered wooden f...
[Closed] Engineered wooden floor - floating or glued?
[#7898466]
14mm, ply based engineered floor onto new concrete and small section of floorboards. Leave it floating or glue it down? It's a DIY fit. Thinking I'll board over the old floorboard section if levels work out. I've helped fit both types before, but undecided here.
Posted : 20/06/2016 8:35 am
I glued mine down. Did a bit of research at the time and decided it was better. Thought you needed the pieces to clip together to make a floating floor?
The glue is stiff as heck and takes a bit of work to spread out nicely. And had to buy quite a specific grooved trowel for it...
Posted : 20/06/2016 9:55 am
I fitted a floating engineered floor over concrete, the planks were click style, looks good and have had no issues since fitting.
Posted : 20/06/2016 10:33 am
Tongue and groove stuff can just be glued together at the join, works fine. Cheap clip together (like a recent job I had using Howdens stuff)can be a total pig to join together as it won't slide sideways; little bits in tight corners need to be angled in two directions simultaneously to get them to clip together.
Posted : 20/06/2016 6:10 pm
We are just going through the same. This is what I was told: Glue for best results (sound/ floor contact). Watch out laying over new concrete. Supposed to give it time to dry out - one month per inch (or until moisture meter less 10%).
All our previous wooden floors have been floating. Usually a bouncy bit somewhere but this may not bother you.
Posted : 20/06/2016 6:49 pm
Yeah, going for glued. Concrete has been down a few months. Going to buy from [url= https://www.poshflooring.co.uk/ ]poshflooring[/url], unless better recommendations or nightmare tales?
Posted : 20/06/2016 7:11 pm
