Enduro!!!!......(st...
[Closed] Enduro!!!!......(stealth tyre thread)
[#7231193]
Currently running Toros 2.35f and 2.15 rear.....love em for just about everything, but I'd like something a bit more secure/planted on the front for our Enduro days......what are the current favourites on here?
Posted : 01/08/2015 11:02 am
Magic mary
Posted : 01/08/2015 11:04 am
WTB Vigilante team on front, fast rolling on back.
OR
Magic Mary front, hand dampf rear.
Posted : 01/08/2015 11:06 am
Trailstar super gravity or snakeskin? Which compound is best suited
Posted : 01/08/2015 11:38 am
DHF 2.5 3C here, love it
Posted : 01/08/2015 11:51 am
Minions Front and Rear, roll pretty well given the grip they give. For trail centre/less steep stuff I run an ardent race, although it can get a bit wayward in the wet, Waiting for the Tomahawk to be available in the UK.
Posted : 01/08/2015 11:57 am
I'm a massive fan of MAXXIS High Rollers, just been away and very one running them pinched, burped, ripped sidewalls etc,
Magic Mary's........ Although only 2 out of 10 were running them, not one drama, they weigh a ton but certainly do their job. I've been converted.
Posted : 01/08/2015 12:01 pm
Magic mary or conti trail king. I'm running a super gravity vertstar MM at the moment and while the grip is immense, it is wearing down at an alarming rate, i will be going for the trailstar compound next.
Are you planning on doing the iom two day enduro in a couple of weeks?
Posted : 01/08/2015 1:11 pm
Maxxis Shorty does the same job as the Mary but is better at [i]everything[/i], even thought the Mary's good there's just no reason to buy it these days imo. If you want one front tyre for #enduroing everything, then Shorty is the best option I've found.
There's others that are better in the dry and in rocks etc though so if you can be bothered to tyre swap then a minion or similiar could be a good second. I'm enjoying the absurdity of my 2.5 29er DHF but it is probably not a sensible tyre 😆
Posted : 01/08/2015 1:29 pm
May have to take a look at the maxxis shorty
Posted : 01/08/2015 1:47 pm
Yes I am slimporcini, well, Saturday only.....I'll be the doddering old mincer slithering around at the back
Trailstar or snakeskin anyone?
Posted : 01/08/2015 2:37 pm
Trailstar is the compound, Snakeskin is the sidewall, for Magic Mary the choice really is Snakeskin or Super Gravity.
I put a Magic Mary Trailstar Super Gravity on the front for the QECP Enduro last weekend - what a tyre, sticks like shit to a blanket. However, coupled with a Trailstar Hans Dampf on the rear, it nearly pulled my legs off trying to pedal uphill. I have gone back to the Pacestar HD on the rear to see if that is any better.
I suppose while the Snakeskin probably saves you 200 odd grams over the Super Gravity, you can probably run lower pressures in the latter. I haven't tried both.
Posted : 01/08/2015 3:04 pm
+1. Even more so as I have mine on a 35mm LB rim!
Looks a bit weird when I'm running a 2.25 Ardent on the back 😆
Posted : 01/08/2015 3:33 pm
So is the shorty better than a Minion or Trail King?
Posted : 01/08/2015 4:11 pm
 poah
and the difference in trail conditions is? just saying enduro doesn't mean anything, its just a type of race.
Posted : 01/08/2015 4:14 pm
2.5 DHF 3C is a fantastic tyre does everything from hardpack to mud fairly well. Paired nicely with a 2.3 DHRII or a 2.4 conti TK at the rear. Still haven't gotten around to try Shorty but I expect it will be my winter combo this year.
Currently running 2015 Butcher Grid front and Slaughter Grid front which weigh a hell of a lot! One of my local rides has some steep fresh cut and it is a little wet the slaughter doesn't grip that well in a straight line but great grip in the corners when you can lean it over.
Posted : 01/08/2015 4:16 pm
Shorty for the win . It's brillbags
Posted : 01/08/2015 4:18 pm
Different. Shorty is evolved from a dh-style cut spike, it's a fair bit better in mud and loose stuff. But is very knobbly so rolls a little slower, and loses out a little on traction when it's on stuff it can't dig into- hardpack trails, rocks.
Minion/Trail King can't match it in the wet, but, roll faster (for equivalent tyres) and have better grip on harder stuff because they don't bite the trail in the same way.
Better/worse? If I could only have one, it's the shorty, because it can cover more bases. Also because the jobs it's less good at, are easier jobs- I'd sooner lose a bit of grip on dry hard trails, and gain a bunch of grip on scottish mud-and-wet-roots #endurobastardry.
Posted : 01/08/2015 4:20 pm
How do you define better?
It grips more than a Minion, but rolls slower. It's not a big tyre either.
The MM grips even more than the Shorty in everything other than sticky mud, which doesn't clear on it.
MM's don't last though. At all. Typical Schwalbe IMO.
I'd probably run a Minion DHF/DHR2 out front & a Spec Slaughter out back if it's dry & have a Shorty to chuck on the front and stick the Minion on the back on the wet days.
Trouble is, my matching tyre brand OCD goes haywire. Hurry up and bring out the Minion SS, Maxxis.
Posted : 01/08/2015 4:26 pm
Ordered this:
Couldn't order WTB Vig as running Trace Enduro 30mm rims, and think I'd have s nightmare putting them on.
So Magic Mary it is: not that bothered about wear, as they'll be on for Enduro races, then off again.
Time will tell whether the "trail comes alive" for me, cheers guys
http://www.chainreactioncycles.com/mobile/schwalbe-magic-mary-evo-mtb-tyre-snakeskin/rp-prod118254
Posted : 01/08/2015 7:53 pm
Magic mary (and all schwable tyres) are pretty cheap on r2-bike.com at the moment, ordered 4 tyres a couple of weeks ago and the whole lot came to £115 delivered. Better than £50 each!
Posted : 01/08/2015 8:03 pm
Sharpie!
Posted : 01/08/2015 8:09 pm
Hob Nob - Member
Not what I found tbh, Mary (in trailstar) didn't grip as well as the shorty (3C) in any conditions ime but was really shown up on wet roots/rocks. Good tread but not that sticky a rubber, I think.
Posted : 01/08/2015 8:39 pm
