elixir 5 brake q
[Closed] elixir 5 brake q
[#3098577]
After a wet ride at dalby on friday i've had to fit some new brake pads on the rear. The thing is, the lever now engages the brake at the slightest pull - i've tried the reach adjustment but I don't see why i'd need to mess with this as the brakes had new pads in from new about 2 weeks ago and the bite wasn't so sudden.
Have I done something wrong when changing the pads over?
Posted : 30/08/2011 11:14 pm
is the brake rubbing when not braking, if not then just move the levers in
if it is rubbing try pushing the pistons all the way back into the housing
Posted : 30/08/2011 11:21 pm
Na, the brakes arent rubbing anymore after i re-positioned the caliper. The lever just doesnt seem as smooth as it was/is on the front brake
Posted : 30/08/2011 11:43 pm
Take wheel out, take pads out, push pistons back, replace pads.
Unfortunately, you don't have the stroke adjust.
Posted : 31/08/2011 12:04 am
Should it be obvious when the pistons are back in their housing? I thought I had pushed them back but perhaps not far enough
Posted : 31/08/2011 10:39 am
