Ekar cranks
Ekar cranks
[#12608172]
Do you need an Ekar bottom bracket or will anything else do?
thanks
Posted : 08/11/2022 7:48 pm
Campagnolo BB’s are different to everyone else’s and you need a special puller to remove the crank
Posted : 08/11/2022 8:15 pm
@dovebiker Ekar uses Ultra-Torque which pulls apart by hand or a swift blow with a lightweight soft mallet after the central bolt in the axle has been undone. Power-Torque is the one requiring the puller and they can set solid, I had to cut the only one I had off the bike as I destroyed my Park Puller and the meatier LBS one groaned as well and they wouldn't continue.
Posted : 08/11/2022 11:00 pm
Campag Ultra Torque cranks / bbs are quite different to others so suspect that you'd need a Campag bb. The bearings are fitted to the crank arms and the arms with bearings attached are then fitted into the bb cups. The NDS has a wavy washer that goes into the cup before the bearing and the DS uses an external retaining clip.
Posted : 09/11/2022 5:01 pm
Oh yeah, and what a great idea Power Torque was. Campag didn't even ever bother making a tool to take them off 😅
Posted : 09/11/2022 5:14 pm
