Edinburgh aluminium...
[Closed] Edinburgh aluminium frame repair
[#6739000]
Was wondering if anyone on here knew of anyone/anywhere that could fix a small hole worn through an aluminium chain stay? The hole is about 2mm diameter at the most. Thanks in advance!
Posted : 31/12/2014 1:51 pm
Welded repair could damage the heat treatment that your frame is subjected to
Truck body builder/repairer might point you in the right direction, you have Weightlifter Scotland in EH29
Posted : 01/01/2015 8:23 am
Aluminium frames aren't generally repairable - they can be TIGed, but that messes up the heat treating.
Posted : 01/01/2015 9:59 am
We have been welding lots of the 7000 series frames ,modernt thinking seems to B aluminium is disposable
Posted : 01/01/2015 11:24 am
Most frames are 6000 series now, aren't they? I wonder if some of that is the shift from small companies without heat treating facilities to much larger manufacturers?
One ambition I have this year is to get my TIG welding up to scratch...
Posted : 01/01/2015 12:57 pm
come and spend a few days in yorkshire ben
Posted : 01/01/2015 6:02 pm
