The DX bike light finally arived and was great on the first outing. Now doesn't want to work. The first time I charged it the charger light went from red to green.
Now when I plug it in the normally green light on the button is red - indicating no battery power, but the charger light is green.
Anybody any experience of this - which bit might be at fault?
Thanks
Did you get the battery pack wet?
I had the same issue; Plugged into the charger and it showed green even though battery was down .
I took the heat shrink off the battery and found the Balancing circuit board damp. Dried it out, and taped back up with insulating tape and now it is all good.
Thanks
Yes -very wet on first outing!
I will stest the bits with a multimeter first - I guess if I strip the heat shrink off the warrenty will be kinda void
