I seem to be going through them too quickly at present, this may well be down to singlespeed use, I guess the best long term solution would be an alternative crank set/bottom bracket.
Can anyone recommend a durable bottom bracket to run with Hollwtechs that is readily available so I can get the bike back in action in the next day or two?
Also any thoughts on a longer term solution....Phil Wood square taper used in conjunction with??
Any thoughts greatly appreciated.
rotorist (previously hardtail)
Posted : 25/01/2009 1:03 pm
Just get some phil wood bearing fitted to your current BB cups (when the your bearings die) by Sideways cycles.
Posted : 25/01/2009 1:55 pm
