Dual ring chain dev...
[Closed] Dual ring chain device?
[#191381]
Can anyone recommend a chain device for a double and bash set up?
I'm running SLX cranks with an E13 bashguard on a Nomad with ISCG 05 mounts on the frame. I'm probably going to be racing a couple of DHs this year and could do with some form of chain retention to avoid losing pedal strokes.
Anyone got any ideas? Would prefer not to spend a fortune.
Posted : 04/01/2009 10:24 pm
E13 DRS :fit and forget:
Posted : 04/01/2009 10:29 pm
I'm running just the arm and roller from an MRP LRP with a dual and bash chainset.
Blackspire Beaver is very similar and i know a couple of people running them.
Fraction of the cost of a DRS but (almost) equitable performance.
Posted : 04/01/2009 10:47 pm
2nd the E13 DRS
well worth the extra 1/5 lb or so in weight.
excellent bit of kit. So much so 3 of my buddies now have em.
Posted : 04/01/2009 10:49 pm
Using a Blackspire Stinger, £12, works perfectly
Posted : 04/01/2009 10:51 pm
Vortex racing, is that half pound including the bashring? Could you provide a closer up pic of the DRS fitted? Cheers
Posted : 04/01/2009 11:58 pm
Blackspire Stinger is pretty good for not much dosh.
E13 DRS *is* better (chain can't drop onto the BB shell, and you have to really clout the dangly bit to bend it), but is a LOT more expensive.
Posted : 05/01/2009 11:42 am
 jedi
drs here. awesome kit
Posted : 05/01/2009 12:32 pm
[img] http://farm2.static.flickr.com/1254/3170785043_a24467be81.jpg [/img][img] http://farm4.static.flickr.com/3105/3171618914_27a0564a7f.jp g" target="_blank">http://farm2.static.flickr.com/1254/3170785043_a24467be81.jpg [/img][img] http://farm4.static.flickr.com/3105/3171618914_27a0564a7f.jp g"/> [/img]
the 1/2 pound is what the DRS itself weighs. I think the whole lot including bash = 1lb
Posted : 05/01/2009 8:33 pm
That's fantastic, cheers.
CRC seem to have a listing on a DRS without the bashring which would seem to be the perfect answer and at only £35 fairly reasonable. Unfortunately, none seem to be in stock.
Posted : 05/01/2009 8:39 pm
I know this topic was a week ago, however if you are after a DRS then I've got one for sale, complete with 40t white bash ring.
Can sort out pics at the weekend (apologies can't do it sooner) but could do it for £40 posted if you're interested? Could probably do with a new roller ( http://www.chainreactioncycles.com/Models.aspx?ModelID=27273) but other than that works fine.
Let me know on greg_barton AT btinternet.com if you're interested - although can't do pics or post it until the weekend.
Posted : 12/01/2009 10:37 pm
cant rememeber what its called but e-13 are doing a more afforable 2-ring device now for about £40
Posted : 12/01/2009 10:56 pm
