DT swiss 350 Front ...
[Closed] DT swiss 350 Front hubs adapters?
[#6926797]
Can these hubs be easily converted with different end caps, I've only seen 15 or 20mm end caps for 240/440 hubs, would these fit?
Thanks.
Posted : 11/03/2015 11:23 pm
The 350 IS disc hubs are available in dedicated QR, 15 mm or 20 mm fronts and completely convertible rear hubs with options for 135 QR, thru bolt versions and 142 mm thru axle versions.
I think the front hubs are not convertible, only rear.
Posted : 12/03/2015 12:26 am
Thanks, not needed now.
Posted : 12/03/2015 9:56 am
You can get a sleeve adaptor to fit inside the 15mm axle to convert to 5mm QR.
Posted : 12/03/2015 10:14 am
