Drilling old Orange...
[Closed] Drilling old Orange 5 for dropper seat post remote
[#7826078]
I have which I am very happy for my occasional off road ventures, XC only and wheels never deliberately leave the ground.
I picked up a 27.2 KS LEV eTENi Integra dropper which I want to an old Orange 5 fit but the frame has no hole for the cable to the remote switch.
I am going to drill the frame, I'm just trying to decide where. Has anyone done this? Any advice - bit size / type etc.
Not bothered about warranty issues just want to minimise risk of sudden frame failure. I have searched for forum posts on this and most refer to cutting a slot for a reverb stealth.
thanks
EV
Posted : 13/05/2016 9:48 am
Forgive my [s]possible[/s] probable stupidity but isn't it going to be the same as a slot for the Reverb except being round?
Posted : 13/05/2016 10:25 am
Round doesn't work as the cable has to be angled to go in. I've done it to a frame, just do it where they do it on the new frame. I don't think they add any reinforcement usually, same as a bottle cage boss hole.
Posted : 13/05/2016 10:53 am
Drill 2 pilot holes, drill 2 bigger holes, file the bit between them out to make a slot. Did it to my pre-stealth bandit 18 months ago and not died yet.
Posted : 13/05/2016 12:01 pm
[url= http://syntace.my1.cc/liteville/pdf/RockShox_Reverb_Stealth_an_Liteville_engl.pdf ]http://syntace.my1.cc/liteville/pdf/RockShox_Reverb_Stealth_an_Liteville_engl.pdf[/url]
This is a useful guide.
you may need a slightly smaller hole for the KS as it won;t have the gubbins on the end of the cable outer.
Posted : 13/05/2016 12:03 pm
Orange sell the necessary grommets.
[url= https://www.orangebikes.co.uk/shop/components/bolts_n_stuff/2015_internal_dropper_routing_guide ]Link[/url]
Posted : 13/05/2016 12:14 pm
Reverb has no gubbins on the end of the cable either, just a bare hose that threads onto a remote.
depends which end you're shoving into the hole honourablegeorge 🙂
Posted : 13/05/2016 12:16 pm
I have done it on 2 frames with no ill effects, doing it to another frame today, CRC sell Vitus cable glands that make it look factory.
One of the frames (carbon) I drilled then elongated a bottle cage boss.
Posted : 13/05/2016 12:25 pm
Thanks for responses, just purchased the Vitus cable gland, do you glue it in the slot?
Posted : 13/05/2016 12:44 pm
wwaswas - Member
I always insert in in the traditional fashion before screwing it on. Ahem.
Posted : 13/05/2016 1:01 pm
The Vitus cable gland just pushes in.
Posted : 16/05/2016 7:52 am
Any chance you could send a photo of the finished slot and what size drill bit you used?
ta
EV
Posted : 16/05/2016 3:38 pm
Thing about grommets and things is they require a bigger hole. I drilled the smallest hole I could possibly get away with then stuck one of these over the top:
https://www.amazon.co.uk/Look-Internal-Brake-Cable-Frame/dp/B00KSF23CA
And added a wee oring to the cable so I can roll it up to the hole. It's not sealed but it's shielded.
For drilling the hole, one thing is, keep it somewhere easy to work on. With Cy's help I got an ideal hole position engineering wise for my hemlock, but it was a total bastard to actually drill and tidy the hole, because of the downtube. I realised after that locating it off to one side would have alleviated this. So when/if I do my Dune I'll do this- and instead of drilling multiple holes etc I hope to pilot it then do a single angled hole the right width, neat and minimal.
Posted : 16/05/2016 3:48 pm
Factory ones have the hole on the down tube just in front of the shock. If you can get the cable round the BB, I'd go for a hole there, might be a pain to drill though.
Posted : 16/05/2016 4:46 pm
I had a Canyon Gland spare, the slot was 8mmx28mm, which seems quite big when you are drilling into the frame.
El Vino - PM me and I will send a photo (otherwise I will forget)
Posted : 17/05/2016 1:53 pm
When I asked for advice for my Rocket was told not under any circumstances to put any holes in the frame whatsoever as all kinds of catastropies would befall
Posted : 17/05/2016 6:10 pm
Different frame innit. FWIW that drilled front triangle is one of the few bits of my Hemlock that I never wore out and broke 😆
Posted : 18/05/2016 1:25 am
