Dried sealant INSID...
[Closed] Dried sealant INSIDE Carbon rims
[#12019422]
Hi all,
I have some dried sealant (apparently!) that has got inside my carbon SC Reserve wheels, it rattles round like plastic inside the rim. When i look at the small bits that come out it is most likely sealant.
The bits are too big to come out of the valve hole or spoke holes - anyone had any experience with this and offer any solutions that wont ruin the rims?!
Posted : 31/08/2021 6:12 pm
Try blowing them out with compressed air; would need access to a compressor, obvs. Even if too big after a few revolutions of the inside of the rim they'd likely be reduced in size?
Posted : 31/08/2021 6:24 pm
If it's sealant, it should be soft and flexible enough to come out with a pick, or tweezers.
If it's hard and brittle, it's more likely resin that's broken loose from the inside
Posted : 31/08/2021 7:01 pm
Was most likely resin in that case. Eventually removed it all - rattling the wheel about and breaking it up bit by bit! Hopefully no issue with the wheel now
Posted : 31/08/2021 7:38 pm
