Double ring and cra...
[Closed] Double ring and crank set
[#2214808]
Hi,
If you were to use a double ring set up what size chain rings would you use, old set up is 22t and 36t. I'm about to fit a new crank also. My new but second hand frame has a X type BB. If im buying a new crank, will the internal diameter of the BB match any crank on the market? ie race face atlas chainset.
Posted : 22/11/2010 9:42 pm
an X type BB is from race face so will fit the Atlas. Shimano use the same BB axle diameter (or rather the shimano is the std). I also use an FSA crank and quite a few others are to this std.
I think it is only the FSA mega exo which is not the std external BB.
Posted : 22/11/2010 10:46 pm
i see, thank you,
Posted : 22/11/2010 11:09 pm
