Double or Triple Ch...
[Closed] Double or Triple Chainset to run Single Ring?
[#4927096]
I know this has been asked before but I couldn’t find a conclusive answer. I’m currently buying bits for a new build which I plan to run 1x10. Am I better off with a double or triple for chainlines etc. Planning on XT cranks if it makes any difference?
And how much difference will I notice running 170mm arms having always used 175mm? All the frames I’m looking at have pretty low bottom brackets.
Posted : 04/03/2013 3:12 pm
Surely if you have 1 ring you just space it to the correct chainline regardless of what chainset it came from originally?
Posted : 04/03/2013 3:17 pm
Triple, so you can use the middle position. BCD will suit most single rings too.
You'll be hard pressed to tell 170 from 175, IMO
Posted : 04/03/2013 3:19 pm
Shortening the cranks will let you spin more quickly. Always a good thing in my opinion. The longer length is supposed to give more leverage off-road, but I never noticed a benefit when moving between 168mm Middleburn Duos and triple ring 175mm XT.
Posted : 04/03/2013 3:21 pm
Thanks fellas, triple 170mm it is unless anyone else has any pearls of wisdom?
Posted : 04/03/2013 8:21 pm
