Does anyone make a ...
[Closed] Does anyone make a floor stand for fat tyres?
[#6780220]
I'm looking for a simple floor stand that I can use in the garage and the back of the van. Ideally something simple with no moving parts that I can bolt down to a sheet of ply.
Something like this;
The problem is I've just looked through hundreds of them and I can't find any that accommodate fat tyres. Everything I've found is 47 or 55mm wide. I need something that will work with the mud tyres on the DH bike.
Surely there's something out there. What do bike shops use? I'm not a fan of the big, heavy, spring loaded ones. I need something with a bit of side support for when I'm pulling G's on the B roads 😉
Any ideas?
Posted : 14/01/2015 6:07 pm
Pop down to the plumbing section of B&Q and knock yourself out.
or
Posted : 14/01/2015 6:11 pm
[quote> http://www.chainreactioncycles.com/ie/en/x-tools-metal-bike-display-stand/rp-prod122327
br />
I thought of those but will it grab a 20mm axle?
And yes, I doubt there's a DIY stand on Google images that I haven't already checked out. I want something a little less hideous.
I'm not above crafting one from scratch but I'll have to wait until the back yard warms up a bit.
Posted : 14/01/2015 6:24 pm
Posted : 14/01/2015 6:25 pm
if you take your front Wheel out you could use a minoura excel vergo (replace any of the standard fork mounts using a bit of 28mm od /20mm id ali tube from flea bay and a selection of hope pro 2 front Wheel inserts any combo of axle dia / lenght is possible I've made inserts for 135mm 9mm axles and 15mm as well)
there are adapters that work with the Thule one as well
Posted : 14/01/2015 6:41 pm
sharkattack - Member
br />
Holds the rear axlw, rather than the fork
Posted : 14/01/2015 6:44 pm
Saris mighty mite,fat bike tyre goes in the gaps.
Posted : 14/01/2015 6:50 pm
Just discovered this;
[url= http://www.sealey.co.uk/PLPageBuilder.asp?gotonode=ViewProduct&method=mViewProduct&productid=14934&productdescription=chock&productcode=&category=31&catgroup=&catmicrogroup=&analysiscode=&requiredresults=16 ]Sealey Wheel Chock[/url]
At 95mm wide it should swallow anything. With a couple of bungee cords over the top of the wheel it should be alright. Cheap enough to grab a couple and see how I get on.
Posted : 14/01/2015 7:22 pm
apart from 4"+ tyres 😉
Posted : 14/01/2015 7:25 pm
Which I will never own.
I hope the thread title didn't give anyone the impression that I have an actual FatbikeTM!
My Muddy Mary's are as fat as it gets round here.
Posted : 14/01/2015 7:35 pm
Turn a dining room chair upside down, should be enough girth to hold a fat tyre in and also double as a fashion stand...much like the bike. 😉
Posted : 14/01/2015 7:51 pm
One of [url= http://www.maplin.co.uk/p/rolling-bike-stand-n36jl ]these[/url] then make new holes wherever you want the uprights to be.
Posted : 14/01/2015 8:04 pm
 JoeG
Fat Rack
[url= http://www.willworx.com/products.html ]http://www.willworx.com/products.html[/url]
Posted : 14/01/2015 8:57 pm
