Disc Rotor Warp - h...
[Closed] Disc Rotor Warp - help please 🙂
[#1030346]
hi guys,
just wondered if the rotor appears to be wobbling inside the caliper does this mean the rotor is warped? its isnt my wheel as i have just had that looked at and tightened so there is no play there?
its just i put new pads in last night and it was a bugger to align perfectly as it on rotation it always caught slightly, then on closer inspection the actual rotor is slightly moving side to side? is it warped?? if so i am pretty novice so have no idea on how to true it, is it easier just to get a new rotor?
cheers in advance 🙂
Posted : 11/11/2009 11:12 am
Use one of these
Posted : 11/11/2009 11:19 am
silly question im sure, but, how exactly? how do you spot whre the ward is also?
sorry for the extremely novice like question 🙁
Posted : 11/11/2009 11:30 am
turn the bike upside down and look at where it hits the pads. Then use an adjustable spanner and bend it back by levering the edge of the rotor. Pretty straight forward
Posted : 11/11/2009 11:47 am
+1 for 59's method, take a little time over it and you'll get it straight, done it many times.
Posted : 11/11/2009 12:04 pm
cool cheers guys ill give it ago me thinks, im assuming it does sound like its a bent/warped rotor then off my description?
Posted : 11/11/2009 12:06 pm
It can only be the rotor that's warped unless you've managed to bend the hub body ...... in which case I'd imagine you'd also be dead 😯
Follow 59's method and you'll be fine. Make sure you don't bend the very outer edge (say 3-5mm) of the rotor by ensuring the rotor is all the way into the jaws of the spanner.
Posted : 11/11/2009 12:12 pm
cheers for the advice, really appreciate it!
Posted : 11/11/2009 12:53 pm
 DT78
Might sound obvious but check all your rotor bolts are done up tight before you go bending the rotor.
Posted : 11/11/2009 1:24 pm
