Disc brake adjustme...
[Closed] Disc brake adjustment
[#1056054]
Had new pad fitted and theres still loads of travel in the levers. There wasnt travel when i bought it so can this be adjusted. Yes im a biff and never had a MTB before 😳
Posted : 19/11/2009 10:42 pm
Probably need bled- bike shop if your not confident.
Posted : 19/11/2009 10:46 pm
Similar to bleeding car brakes in the olden days?? 🙂
Posted : 19/11/2009 10:49 pm
What brakes are they? Some have reach and bite point adjustment.
Posted : 19/11/2009 10:50 pm
you mean hydraulic discs ?
WHo put in the new pads, and did they do anything else to the brakes, like letting a bit of fluid out maybe ?
How would you describe the problem:
1) loads of travel & then good braking with your levers quite close to the bars but not touching ?
2) loads of travel, levers resch the bars before braking starts to happen
3) braking starts early but spongy & lever continues to pull inwards ?
If it's 1, rejoice - your hands will get less tired on long downhills this way (move the levers inwards a bit away from the grips & use 1 or maybe 2 fingers to brake if you're not already - this'll stop you crushing other fingers under the lever). Whoever did you brakes for you might have altered a reach-adjuster (not all brakes have one)
if it's 2, it may just be that the pistons need to reset (they auto-adjust as the pads wear - pistons push a bit further out through the seals) bit of lever pulling might sort this or you could try CAREFULLY pulling lever with something a little thinner than your rotor between the pads to make the resetting easier. You can go too far & find it hard to get the rotor back into the gap so be careful (do not pull lever when there's nothing between the pads or you'll end up shoving pistons back in and maybe damaging stuff)
if it's 3 - maybe need a bleed (but hard to see why a pad change would cause this)
Posted : 19/11/2009 10:57 pm
Using Hope Tech X2 and TBH, they are a PITA to adjust so that the disc doesn't rub. Pads need to come out about 10 thou per side but of course, you can't ****ing do this!! 👿
Oh, the joy of my Kooka Unitwin cable ones that allowed individual adjustment of all four pads. Still, price you pay for having hydraulics with their better stopping power and auto wear adjustment, I guess. 😥
Posted : 20/11/2009 12:07 am
Oldgit - check the hope site for videos with tips for centring the pads - you should be able to get them to run with no rub assuming the disc is straight
Posted : 20/11/2009 12:17 am
