dirty brake fluid.
[Closed] dirty brake fluid.
[#5453540]
Evening.
Opinions/advice please.
Bled my brakes tonight. Front was fine, fluid pushed out was still clear and golden. Back brake pushed out black fluid, had to bleed it several times to get clean fluid.
Is this a symptom of something else? Its a sealed system, so I am thinking that it is leaking somewhere, contaminating the fluid? Or is this just what happens eventually.
Brakes are avid juicys if this matters.
Posted : 24/08/2013 9:15 pm
 Spin
That. In my experience any way.
Posted : 24/08/2013 9:19 pm
Had the same thing on a set of hayes 9
Fluid had almost gone gelatinous and was holding air - took me a long time to get em clean and working!
Posted : 24/08/2013 9:22 pm
Thanks.
It has always pushed through clean when I did it previously. Jut concerned that it was a symptom of something worse.
Posted : 24/08/2013 9:40 pm
It's common for car brake and clutch fluid to come out black.
It's caused by minute particles of aluminium and rubber as the cylinders and seals wear.
It's normally nothing to worry about.
The system is under pressure in use. If it was leaking, fluid would be getting out, not dirt getting in.
Posted : 25/08/2013 7:04 am
Mine is dirty as well. Happens after heavy use, and in my case, after trips to the Alps. I might flush them for peace of mind
Posted : 25/08/2013 2:38 pm
As everyone has already said, it just indicates that the fluid is very old. We recommend people flush the system a couple of times to make sure the new fluid has replaced all of the old.
Posted : 28/08/2013 10:58 am
