Dint in a 717 rim ...
[Closed] Dint in a 717 rim can i straiten it out.
[#3417432]
Iv,e got a wee dint on the edge of my 717 rim.
It,s about an inch long and dinted inwards by about 3mm
Is there any reason why i can,t rig up a clamp with two thin strips of steel and press it out.
Cheers all...
Posted : 01/12/2011 10:20 pm
no problem
Posted : 01/12/2011 10:22 pm
717 disc or the one with the braking surface?
I've pulled dings out with an adjustable spanner plenty of times in the past. Doesn't sound too bad - I reckon it'll be fine.
Posted : 01/12/2011 10:23 pm
Most use an adjustable spanner, i've ground the jaws of one to fit without damaging the rim, but a normal one will do.
Cheers all
Just didn,t want to go for it and do some damage...
Posted : 01/12/2011 10:24 pm
mole grips, shifting spanner (has to be imperial though), or just a narrow spanner do the job nicely
Posted : 01/12/2011 10:25 pm
 Spin
Don't use mole grips. The teeth can mark the rim. Adjustable spanner done up nice and tight will do the trick.
Posted : 01/12/2011 10:43 pm
straiten ??? straighten 😉
Posted : 01/12/2011 10:49 pm
You need this:
http://www.morningstartools.com/rim-rench.html
Only $20 shipped. Their is a review on bikeradar aswell
Posted : 01/12/2011 10:52 pm
depending on the damage done, I often find the teeth marks are no longer an issue 😉
Posted : 01/12/2011 11:06 pm
That Rim Rench thing looks just the ticket.
I get out the Big Bits Of Wood and Assorted Drifts And Funny Shaped Bits of Metal and most importantly a coarse grade hammer... Place wheel flat on the BBOWs so that the dink is downwards, select an ADOFSBOM which looks the right size and shape to whack the other side of the dink, then apply hammer.
Posted : 01/12/2011 11:10 pm
I'm not too keen when it's folded but if it's just rounded over a bit it's usually fine. If it's folded it'll fatigue fail and the tyre will blow off. Had it happen 😀
Posted : 01/12/2011 11:29 pm
I straightened out a slightly buckled 717 rim. Of course it'll probbly eventually explode, killing me instantly or something, but it's bin fine for several months now. 😀
Posted : 01/12/2011 11:31 pm
I had a bad ding in a 5.1 rim - probably 3 cm long and 1 cm pushed in - straightened with a adjustable, it didn't crack and 18 months later is still fine
Posted : 01/12/2011 11:33 pm
Adjustable spanner works good. Its something you will become accustom to if you ride 717-pencil prick rims as my mate calls them
Posted : 02/12/2011 1:31 am
