Difference between ...
[Closed] Difference between 180mm and 183mm rotors?
 Leku
[#3008725]
And for the love of God and think of the children's faces PLEASE don't say 3mm.
Looking to get a new front rotor. Have a Hope Pro II hub and Hope mono mini brake. Merlin have the floating saw rotor I want at a good price but it is 183mm. Will that fit using a 180mm Shimano brake mount or would I need Hope 183mm mount?
Posted : 02/08/2011 10:35 am
 MSP
iirc, the mounts are the same, the 3mm difference is in the calliper, and hope are 183mm (but I could be wrong). email hope.
Posted : 02/08/2011 10:38 am
I believe there's a 1.5mm difference in radius...
 Leku
Posted : 02/08/2011 10:42 am
couple of washers between caliper and mount should sort it. I did this with a 203mm rotor and a mono M4 caliper- it rubbed otherwise
Posted : 02/08/2011 12:01 pm
180mm rotors were for IS mounted calipers, 183mm are for PM.
Posted : 02/08/2011 7:24 pm
With 183mm rotors you have a lessened braking distance, by 3 mm.
Posted : 02/08/2011 7:49 pm
 Leku
I emailed Hope and they called me back within an hour or so (which is why I will always buy Hope products whenever I can).
183mm rotor requires their 'H' 183mm bracket.
Posted : 02/08/2011 8:38 pm
