If cost were not an issue, imagine a commuter bike with di2 alfine fitted. No cable stretch, minimal chain wear, no rear/front mech alignment issues, no adjustments needed, no jockey wheel wear, no mech to snap off. Just a bit of lube on the chain every now and again (or fit a Gates belt and do away with that) and a charge of the battery twice a year. Surely that's a benefit?Hear, hear! Add in a hub dynamo on the front, perhaps even one that could trickle charge the battery during daylight hours, as you point out and you've got pretty much my dream 'bike as a means of transport' bike.
Oh, and full length mudguards, obviously.
I'm with you all here though.
Are you using a freehub to allow a stronger rear wheel build with less dish? Or less deflection and less wear on the chain?
6x 9spd cogs on a Hope SS hub - 3xSS cogs and 3 std shimano ones. Durable, clag-resistant and if the mech rips off I can re-align it all as a SS with a choice of gears (EBB on the bike). Strong back wheel and same spoke size on F+R, L+R.
About as likely to need those get-out features as my DI2 going flat : ) I feel confident that I can fix almost anything on the bike with that set up, electronics is something I'm less confident with.
Very interesting, cheers, I didn't know there was that much room on a hope SS hub.
Friction thumbies as well?
'k off : ) no.
Barenders on Paul mounts so they do have a friction option - more about bar / bag space, grip range etc tho.
Jameso - do you have a picture of your TD bike
Fair point. The only people who this might benefit are professional racers and anyone who's got enough disposable income to be considering high-end groupsets.But njee20 claims:
There are benefits for everyone
So which is it?
Woah woah woah woah!
I said (as you quote) "There are benefits for everyone". That is not "It will benefit everyone", it's an entirely different statement.
Mugging someone has benefits - you end up with their money and phone. We don't do it for various reasons; moral compass, jail time etc etc, but that doesn't detract from the fact that commiting the robbery has benefits, just that the negatives (in this example far) outweigh the benefits.
So yes, Di2 has benefits for everyone. It is not beneficial to everyone. Subtle but important difference there.
No, just something that works reliably and isn't unnecessarily overcomplicated.
Sounds like you need Di2, far simpler than anything mechanical - you ever looked inside an STI lever?
You should get a job in marketing. You're a natural. Those power balance band folk would love you.
Yes. You ever looked inside a downtube shifter? 😉
So you never bothered with indexed shifting because they are unnecessarily complicated and a solution to a problem that doesn't exist?
I made an important distinction, you ignored it.
Point is that STIs function better than downtube shifters, they're more complex, but the overwhelming majority of folk would always choose STIs because of the benefits (there it is again, try and keep up). If you use downtube shifters then I'm starting to understand, although I assume your pursuit of relentless simplicity has lead you to singlespeed.
although I assume your pursuit of relentless simplicity has lead you to [s]singlespeed[/s] walking.
FTFY
quite surprised you didn't get that, there's lots of cool stuff I could buy that would be of benefit but I don't buy them all coz I'm not minted. Just coz they cost too much for me doesn't mean they wouldn't benefit me.There are benefits for everyoneSo which is it?
Looking forward to Di2 XT for my bestest bike, workhorse bikes will be using gear cables for a while longer i think
That's such a developed-world-road-bike-enthusiasts' viewpoint njee, you should be ashamed.
What about the baby african robins's faces? Mmmm?
dp
Your application of Occam's Razor could have led you to Wackoak's suggestion, had you taken it to it's conclusion. 🙄
Indexed shifiting offers a genuine and obvious improvement over non-indexed. As do V/disc brake systems over calipers/cantis. So, it's common sense to 'upgrade' if you ant to enjoy the benefits.
As to Di2; I'm sure there are those who enjoy the benefits of that system over a mechanical one, although my own and others' experience of it suggests an 'benefits' are both negligible and not worth the added expense and complexity. Your personal experience may differ. Great. Buy it.
Ok, so enlighten me as to exactly what it was you meant.
'Better' is a subjective term. I'd argue that due to their increased reliability over time, downtube shifters could be seen as 'better', depending on your own personal perspective. My own road bike uses bar end shifters (10+ years old and still as good as new). As someone said earlier; horses for courses.
My commuter bike is singlespeed; no derailleurs, shifters, extra cables, batteries or electronics to worry about.
Notice how Shimano haven't bothered with an electronic braking system? I wonder why that is? After all, cables get gungy and snap, etc. 😉
What experience of Di2 do [b]you [/b]have? In the real world? Becuase everything you've said about it screams ill informed.
I've already said three times now and it's getting painful - there are benefits: it weighs less, it is easier to use and more reliable. Those things are likely more than offset by the disadvantages for most people, but it doesn't stop those things being benefits.
As is the STI on my road bike which didn't die in the cable failing incident. It's much nicer to use than a bar end shifter too. What's your point caller?
You're kidding, right? Digital signals don't translate all that well to brakes. Hydraulic however... if you'd looked around of late you'd see that both SRAM and Shimano are doing hydraulic road brakes.
Personally for me I'm not fussed, but I can see there are benefits.
I don't ride bikes THAT much, don't race, don't have that much spare cash.
But if electronic gears meant that during the winter I didn't have to tinker with the brakes to stop them going 'per-ting per-ting per-ting graunch clunk' then I'd have them (ahem, if they did them in a budget 'slx' type range).
Issues such as wires breaking would be dead easy to solve (run the wire through a cable outer?) and I thought with Di2 rear mechs (from the little I have seen) if there is some kind of mechanical that wrecks the mech, then it is designed to shear off and save the electronic gubbins from a horrible death?
The battery charging being an issue thing is a joke. As I understand it, you get hundreds of miles from a low battery warning to actual battery death.
Presumably an electronic braking system would require a lot more power, so wouldn't be viable/sensible.
I'd have a go. Maybe XT or SLX level.
What about trimming the cables to suit your bike? Easy to do?
My niner had to have the loom extended to fit the longer niner frame (road bikes tend to be shorter and mine is a Di2 conversion, not XTR). It was a bit of a faff but once done its posed no problems
What experience of Di2 do you have? In the real world? Becuase everything you've said about it screams ill informed.
Limited to testing a D12 equipped bike for a day. Limited I know, but sufficient for me to make my own judgments based on my own particular needs. Although front-ring upshifts are awesome I have to say.
It will if you don't explain yourself clearly. 😉
Ok; for example, v brakes offer vastly superior braking performance to cantis or caliper systems. V brakes are relatively cheap to develop and produce (the original XT ones were bloody expensive if I remember right though). Ergo, their development 'benefits' a great many cyclists. Di2 on the other hand, is a technology which is very unlikely to ever be all that cheap, therefore it won't benefit anywhere near the same number of cyclists. So your claim that there are 'benefits for all' is somewhat disingenuous. Personally I'm more interested in developments and innovations that benefit cyclists universally, you appear more concerned with your own needs. Everyone's different.
My own personal set up means that STI's won't work very well as I can't position them where they'd be comfortable and effective in use. That's all.
You seem to have me down as some sort of luddite, simply because I questioned the 'benefits' (for most cyclists) of Di2. I'm not. Interesting that you seem to want me to be though.
I'd be interested in seeing weights and prices for Di2 v mechanical groupsets.
Interesting. So, imagining a hybrid electronic/hydraulic system, would a braking system require a lot more power?
Haven't we been here before?
**looks down list of names**
Nope, luddite isn't on there. You preach about benefits to the 3rd world and simplicity and what not, which I suppose could be misconstrued as being a luddite. No one's used that term though. You yourself said cycling is all about having a bike that's as simple as possible or words to that effect.
You still don't get what I'm saying do you? I'll try once more, I'll use a different example again. Mr X drives a Fiesta. He looks at a Ferrari. There are benefits with the Ferrari, we'll keep it really simple, and say that the only one is that it's faster. Mr X will not be buying the Ferrari because it is ludicrously expensive, but that does not stop it being faster. That is still a (potential) benefit. Do you see? It doesn't save the faces of African baby robins, but it has a benefit.
You seem to be looking at the benefits to the world, which whilst somewhat noble, also seems rather misguided when talking about something like the cutting edge of mountain bike development.
I think you lost sight of whatever it was yourself, some time ago. Coming up with guff like 'Digital signals don't translate all that well to brakes' convinced me you're simply spouting whatever it is you want to believe. Rather than continue what has now become a pointless argument, I'm going to leave it there, but thanks for your input all the same.
I'd still however be interested in comparative weights and prices of Di2 and mechanical systems.
What, two people arguing in [i]tandem[/i]? Yes, we have.
You think that an 'on/off' switch would be good for brakes!? Agree you could have something that works on pressure switches and what not, but hydraulic makes a lot more sense.
What, two people arguing in tandem? Yes, we have.
Haha, dammit I got drawn in! Should know better than the feed the trolls.
Can (obviously) only offer you road stuff: [url= http://www.bikerumor.com/2013/03/12/unboxed-shimano-di2-9070-actual-weights/ ]here[/url].
No we haven't!
What, two people arguing in [b]tandem[/b]? Yes, we have.
i thought he got banned...... 😆
That was CFHs joke I think...
As amusing as all of this is, what I would like to know is if bikeind's colleague has ever made it back from his travels to Japan and can tell us all about it?
Or did he just wake up with his head in his cornflakes?
