Derailleur question
[Closed] Derailleur question
[#4077554]
I have just bought a second hand mountain bike for my sons and have noticed that the rear derailleur is a sunrace M30 seven speed. The issue is that the bike is a 8 speed (8 cogs on the back)does it matter or will it work the same?
Posted : 17/06/2012 8:15 pm
Does it work?
Remember that the derailleur doesn't know how many sprockets there are, at least not until they get 10 speed or so...
Posted : 17/06/2012 8:17 pm
8-speed cassette needs an 8 or 9-sp chain and an 8-sp shifter.
Most Shimano rear mechs up to and including 9-speed will work for 6,7,8 or 9 but not 10-speed.
If the rear mech moves far enough in and out then all is fine.
I have had mechs that did not move in or out (different mechs) to cover the range required on mix-n-match hubs and frames.
Final point, max sprocket size is sometimes stamped on the mech...and is usually a bit conservative.
PaulD
Posted : 17/06/2012 8:39 pm
