Deore brake problem
[Closed] Deore brake problem
 core
[#7596564]
My back brake was dragging a bit, and the pads shot, so I put new fresh pads in, gave it a quick bleed, and ever since the lever goes solid, once the pistons have come out to meet the bleed block/pads have contacted the disc, there's no travel on the lever, it's like it's locked out.
Hoping there's a simple answer/cure?
Sam
Posted : 22/01/2016 6:31 pm
Not worth bothering with Tbf,see here £19.99 for a set ➡
http://www.chainreactioncycles.com/shimano-deore-m615-disc-brake-lever/rp-prod108825?gs=1&gclid=CjwKEAiAw4e1
Posted : 22/01/2016 6:47 pm
difficult to tell from ^^
and not sure that a new lever is going to fix whatever is the problem
remove the bleed block, do the pistons both move and independently?
were they fully retracted when you did the bleed?
Posted : 22/01/2016 7:16 pm
