Deore brake pads qu...
[Closed] Deore brake pads quick question
[#8087183]
Anyone happen to know the brake pad code for Shimano ice tech pads that will fit 2015 deore brakes (br m615)? Details seem a bit shaky on the usual online sources. Normally I'd ask the lbs but can't get there for another week.
I'm a heavy blighter and the ones in there seem to be the first set of brakes I've never cooked so I'm prepared to cough up for these over standard.
Posted : 02/10/2016 9:55 pm
Y8KA98010 Resin Pad (G01S) & Spring w/Split Pin
Y8JZ98020 Metal Pad (G03S) & Spring w/Split Pin
Edit: Ah, they're not ice tech ones, just the standard. Think it's SLX and above that come with those...
Y8J79801A Resin Pad (F01A) w/Fin & Spring w/Split Pin
Y8J79802A Metal Pad (F03C) w/Fin & Spring w/Split Pin
Posted : 02/10/2016 9:59 pm
Perfect thanks. 😀
Posted : 02/10/2016 10:06 pm
Here you go.Shimano tech page.[url= http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR/EV-BR-M675-R-3286_v1_m56577569830800233.pdf ]link[/url]
Posted : 02/10/2016 10:20 pm
