Darkside - Removing...
[Closed] Darkside - Removing a dura-ace crankset
 Alek
[#1637924]
Need to service a dura-ace crankset. Crankset came with the bike but do I need any special tools/fitments to remove (7800) been searching the web but hav'nt found anything.
Alek
Posted : 24/05/2010 1:48 pm
So far as I'm aware, it's the same as XTR M960.
1.) Undo the two NDS bolts.
2.) Undo the NDS end cap (if you don't have the tool 2 butter knives do fine)
3.) Remove the NDS arm.
4.) Gently tap the axle through with a rubber mallet to remove the DS arm and captive axle.
Posted : 24/05/2010 1:52 pm
Exactly the same as all HT2 chainsets except M970, you need a TL-FC16 to undo the end cap, £3 from any LBS.
Undo the 2 bolts with a 5mm allen key, undo end cap, remove LH crank, remove RH crank.
Edit: too slow!
Posted : 24/05/2010 1:53 pm
 Alek
Cheers guys.........
plan is, to give this a go tomorrow.
Posted : 24/05/2010 9:43 pm
Park tools website for tips
Posted : 24/05/2010 9:45 pm
 Alek
Excellent....will go and take a quick look. Reckon its no different to any other HT2 which I've done plenty off.
Posted : 24/05/2010 10:28 pm
http://www.parktool.com/repair/readhowto.asp?id=95
Next to the HT2 heading I think.
Posted : 24/05/2010 10:40 pm
