Damaged rebound kno...
[Closed] Damaged rebound knob on Rockshox forks.
[#5936823]
I've not taken any of my forks apart yet know bugger all about any of them but noticed the rebound is not central! Seems to turn around ok ish (12-13 clicks) catches the forks though.
Easy to fix or is it more involved or just leave as is?
[img] ?t=1392058219[/img]
TIA
Posted : 10/02/2014 8:00 pm
 nuke
Can you pull the rebound knob off? It should just pull off although dirt etc can make them quite hard to remove. With a bit of luck, might just be that thats bent.
Should look like this once removed...
[img] https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcSnwcUZox8R6-8E77FLc4T3xWu17kER8NBGe5aMqDndBL_Zsevc [/img]
Posted : 10/02/2014 8:02 pm
hmm. That's not good! Hopefully it has just come downwards and bent the allen key bit. Got a shot looking up into the hole?
Posted : 10/02/2014 8:03 pm
I'll have another look at them tomorrow, thanks for replies.
Didn't know that it was a push fit but thinking about it it couldn't be threaded could it lol...
If it does come out ok I'll try straightening it, and prob snap the bugger!
Posted : 10/02/2014 9:28 pm
 nuke
[i]If it does come out ok I'll try straightening it, and prob snap the bugger![/i]
If its broken, it doesn't matter anyway as you can just use an allen key to adjust the rebound instead...all the rebound knob is is a allen key with a nice anodised red knob on the end of it <s****>
Posted : 10/02/2014 9:32 pm
Good point nuke ta.
Posted : 10/02/2014 11:19 pm
