cut in tyre sidewal...
[Closed] cut in tyre sidewall (tubeless)
 ed34
[#1731533]
got a small cut (about 7mm long) in the rubber on the side of my tubeless tyre (specialized captain). I can see some of the tyre threads through it but they tyre isnt losing air.
Can i fix it / reinforce it from the outside with some glue and a patch? Dont want to take off if possible as its full of gloop.
Or is it likely to fail horribly on the next rocky descent so i should just get a new one?
Posted : 23/06/2010 9:02 am
Just fit an external patch - should work fine
Posted : 23/06/2010 9:07 am
deflate it a bit
put some superglue in the cut
squeeze the cut together while it dries
reinflate
this has worked for me on a number of occasions.
Posted : 23/06/2010 9:10 am
