Hi all,
Been lurking a while but first post as I'm looking for some advice on a potential new bike 🙂
I'm currently looking at the Cube Stereos and basically wondering if it is worth splashing out the extra £500 on the Stereo Race or the Stereo Pro
Spec for Race
Cube Stereo Race Full Suspension Mountain Bike Specifications:
Frame: HPA 7005 Advanced Hydroform DTC Triple Butted, FSP 4_Link_System, X-12
Forks: Fox Factory 32 Talas FIT RLC 120/150mm, Lockout, 15mm axle
Rear Suspension: Fox Factory Float RP23 BV 190x51 mm length
Headset: FSA Orbit Z 1.5R semi integrated
Stem: Syntace Megaforce2 Oversized
Handlebars: Syntace Vector DH 318 Oversized
Grip: CUBE Fritzz Screw-On-Grip
Rear Derailleur: Shimano Deore XT RD-M780 Shadow 10-speed
Front Derailleur: Shimano Deore XT FD-M780 Top Swing, 34.9mm, 10-speed
Shifter: Shimano Deore XT SL-M780 Rapidfire-Plus, 10-speed
Brakes: Formula RX Tune hydr. discbrake (180/180mm)
Cranks: Shimano Deore XT FC-M780 Hollowtech II 42x32x24T, 175mm, integrated BB, 3x10 speed
Wheels: Easton EXP500 wheelset 15QR / X12
Tyres: Schwalbe Fat Albert Rear Kevlar Triple Compound 2.4
Inner Tube: SV13F Freeride Light
Pedals: None
Saddle: RFR Trail Shape 0.1 M
Seat Post: Syntace P6 Alloy 34.9mm
Seat Clamp: Syntace Superlock 38.0mm
Weight: 13.3 kg
Spec for Pro
Frame: HPA 7005 Advanced Hydroform DTC Triple Butted, FSP 4 Link System, X-12
Forks: Rock Shox Revelation RL Air 2P 120/150mm, Motion Control, PopLoc
Rear Suspension: Fox Performance Float RP23 BSD 190x51mm length
Front Derailleur: Shimano SLX FD-M660-10 Top Swing, 34.9mm, 10-speed
Shifter: Shimano SLX SL-M660-10 Rapidfire-Plus, 10-speed
Brakes: Formula RX hydr. discbrake (180/180mm)
Cranks: Shimano FC-M552 2-Piece 42x32x24T, 175mm, integrated BB, 3x10 speed
Wheels: Sun Ringlé Radium wheelset, 32 spokes, QR / X12
Pedals: None
Weight: 13.6 kg
Any other recommendations in this price as well?
The main difference looks to be in the fork, no idea what dif a Fox Factory RP23 and Fox Performance RP23 makes, I suspect none that you would detect. XT and SLX dif is not very much, few grammes and barely noticeable in performance. I'd be inclined to suggest the £500 cheaper Stereo and consider selling the forks as new and upgrading the forks for slight second Fox or similar (should beable to still save yourself around £500).
I have a 2011 Stereo team.
Full XT, RP23 and Revs.
The 23 is great, XT v's SLX is little or no difference.
The Revs are a great fork and require less servicing.
Try and pick up a 2011 model if available
I'd go for the cheaper version just to avoid the Fox fork, but thats just a personal issue with Fox forks. My mates own a Cube dealership and have just received one of the first 2012 Stereos. I think he has ridden it a couple of times since it arrived middle of last week. They ran the Stereos last year and i have a Fritzz which i love. Give them a bell and they can give you some advice on which one to go for (and availability - 2011 are all gone)
Twelve50 Bikes in Frodsham Cheshire 01928 898011... ask for Matt or Rick.
If you need a 20" then can we poke you towards this http://www.thebikechain.co.uk/Cube-Stereo-Race-20-2011081209/
Cheers for all the info.
Wow, that's a very good price on 2011 stereo race which i'm very much now condsidering as I think an 18" is slightly too small
Couple of shops I've spoken to down here (Cardiff) say they won't have any availability until January
Mccet, i'll give them a ring, cheers.
