Is it possible to fit 15mm converters to 08 crossmax st wheels to fit latest fox qr15 forx, anyone know ?
Thanks.
ST's are either 20mm or QR not both, unlike the old XL or SX which could take converters. Hope this helps.
Ta
I read that you could convert them, was thinking of doing mine but then got a pair of 36's. A quick Google found [url= http://www.bikemagic.com/news/article/mps/uan/6310 ]this.[/url]
markcdo
I think I might be wrong not sure now, if the ST's can be converted between QR and 20mm like the old XL's. You can then you can sort this, as a mate had his XL's sorted to fit 15mm. I have the Sl's and you can't convert them. You can easily tell - pull the adaptors on the hub off and look inside if there's a hexbolt in the hub it can't be done.
He had the old 9mm adaptors milled/drilled out to 15mm. The lad that did it has some engineering experience and is a member on here 'NorthCountryBoy'. Might be worth getting in touch for some info. Strangely Northcountryboy bought ridethelakes epiphany off him....small world 🙂
