Creaking saddle/sea...
[Closed] Creaking saddle/seatpost cures?
 SiB
[#607551]
I'm pretty sure its coming from the saddle as when out of saddle it doesn't happen! I have applied carbon grease to saddle rails and all parts that can be tightened but everytime I go over the slightest bump theres like a creaking/cracking noise coming from saddle area. Newish bike, no signs of wear and tear or any damage.
Any suggestions greatly appreciated as sick of people starring at me and my noisey bike!!
Posted : 05/06/2009 12:15 pm
It's often the seatpost clamp (ie what holds the seatpost in the frame) - take apart grease and add grease between it and the frame. My Bianchi road bike did exactly the same when new...
Posted : 05/06/2009 12:17 pm
could be how the rails join the body. A little light lube maybe.
Had exactly the same problem, I greased the seatpost & shim (using carbon grease, make sure you do this if your frame is carbon!), greased the seat rails, and still had the annoying creak/crack everytime I hit a bump... worked out yesterday it was the seatclamp, a dab of carbon grease there and it is now sorted 😀
Posted : 05/06/2009 12:20 pm
 Olly
mine is in the mount between the rails and the saddle body.
it makes me want to cry 🙁
its SO irritating.
not a lot i can do i dont think.
other than squirt it with grease every now and again
Posted : 05/06/2009 12:22 pm
 SiB
It is soooooo annoying but at least now I'm riding alot more out of the saddle! Will try grease on the the clamp later and keep fingers crossed. If that doesn't solve the problem then a bit more grease here and there will hopefully do the job......and then a bit more if it persists!
What are the smallest hard to detect noises the most irritating??!
Thanks for advice
Posted : 05/06/2009 12:27 pm
Mine was doing that last week, I applied 'brand new thomson post' to the issue and it went away.
Any excuse
Jez
Posted : 05/06/2009 12:34 pm
 SiB
I like your way of thinking Jez!
Posted : 05/06/2009 12:36 pm
